PSdZData FULL Requests (Programming Firmware)
1.1M views 11K replies 3.9K participants last post by  shawnsheridan
#1 · (Edited by Moderator)
Hello,
I have version 57.3
Is there a newer version?
What is the newer version?
What does it give over the older version?
Most important, is it needed for a 2016 M3?
#10,574 ·
#10,587 ·
Shaw, Hi. I'm a mechanic that wants to learn basics of coding. I'm new to this. From what I've read, I bought an ENET cable, a fresh laptop, installed Esys 3.30 with accompanying softwares/launchers. Now I need to remove PPS system from my f10 2010. Psdzdata lite enough to do it, correct? If so, which data version do I need to work with my car and Esys 3.30 version, and where would I get that? Searched the internet all day and couldn't find any links that haven't expired. Thank you in advance for any help.
#10,588 ·
I do not know what PPS System is, but I assume you are removing via Coding, in which case PSdZData LIte is fine. Use latest. PM sent.
#10,592 ·
When trying to execute the TAl actually...
Warning.
Missing SWEs in PSzData directory. [C201]
ATM_0x61
flsl_000026a3-001_043_020
This is not an issue for flashing Gateway module. Ignore it.
#10,597 ·
E-Sys => Options => Settings => Options and Uncheck Box for "Check software availability before TAL execution". Then flash.
#10,604 ·
TAl processed. lots of errors...'resource not available'
is there something different i need to do to flash the central gateway... flexray is still offline.
TAL executed on a little over 2 minutes.. lots of errors 'resource not available'
flexray is still offline. the BDC executed properly. What do i need to do the flash the Central Gateway??
Did you try just initializing Flexray in ISTA?
#10,608 ·
I can not connect to ISTA any longer... I did try with protools. it would not initalize.. I have tried to connect using ip 192.168.0.1 and DHCP Server, get to ZGW or any EUs...
no ZGW or any EUs found.
Now I cannot get back to enet connection via vin..
I have no idea what is going on there.
#10,609 ·
Changed put the BDC for new, was able tu use esys and get most modules on line by doing a complete TAL. Some modules did not program on the Flexray circuit. Was able with Protool to initialize flexray... Still unable to connect ISTA>>> either enet or icom clone... Snapon connects, protool connects, esys Connects, beginning something has crashed in my ISTA install.
Will net try Esys again to see if I can get the remaining modules online...
Any other suggestions???
Thanks for your assistance...
#10,610 ·
Open Windows Explorer, find EDIABS.ini file in the ISTA EDIABAS folder, and open it in Notepad, and change the Interface = line as follows:
"INTERFACE =ENET"
ISTA has its own EDIABAS folder that it uses, so it does not use EDIABAS from BMW Standard Tools installed to c:\EDIABAS.
Then set ISTA to use EDIABAS Connection.
#10,613 ·
Everything that is not communication is on the Pt-CAn bus.... ..We have had recently all those modules working, and have exchange 3 of them beginning with Crash module and fuel pump control and the PCU... nothing changed.. Esys does not see the 7 modules so I cannot program them from there.... it is a mess as you said....
#10,622 ·
Hello,
I have noticed there is no CAFD for the BDC, I have been unable to inject one...I get a PSdZ Error, "Failed to get SWE "swf_00002419-085_010_130". (C111)
KIS error: Die techninsche Einheil 000021419 konnte in der KIS-Wissenbasis nicht gefunden werden (1283)
#10,615 ·
Hi Shawn,
I would greatly appreciate it if you wouldn't mind sharing download links for the latest Esys and full PSdZData.
Thank you very much!
PM sent.
