PSdZData FULL Requests (Programming Firmware)
1.1M views 11K replies 3.9K participants last post by  shawnsheridan
#1 · (Edited by Moderator)
Hello,
I have version 57.3
Is there a newer version?
What is the newer version?
What does it give over the older version?
Most important, is it needed for a 2016 M3?
#10,687 ·
hi shawn, my car M135i currently replacing used vdc module and have missing SWE btld_00001c4e-005_002_000 file on psdzdata on tal processing. i have try a few latest psdzdata up until the latest 4.53.30 and still missing the btld_00001c4e-005_002_000 file.
what i read in the forum, that file is available on old v58 psdzdata, or any version that you recommend that have the missing swe?
#10,689 ·
I have no idea what version(s) it is in, and I do not keep any older versions. I have always only the latest.
#10,699 ·
#10,706 ·
54.1 is from November 2012, so it is almost 13 years old. If car has newer than 54.1, and it almost certainly does, you cannot use 54.1. You need to use latets psdzdata and a CAFD Mapping solution such as BimmerUtility.
  • Like
Reactions: ajoceba
#10,712 ·
La versión 54.1 es de noviembre de 2012, por lo que tiene casi 13 años. Si el coche tiene una versión más reciente que la 54.1 (y es casi seguro que la tiene), no puede usarla. Necesita usar psdzdata actualizado y una solución de mapeo CAFD como BimmerUtility.
[/CITA]
F20-18-07-547 es el nivel de integraciĂłn que psdzdata recomienda?
#10,713 ·
This is from July 2018. 54.1 is from Novemeber 2012, which is way too old to use.
#10,725 ·
Hi everyone, I'm looking for the latest full PSDZData package. If you have it available, please send me a PM – much appreciated! Also: Is there any ISTA+ version newer than 4.39.x that is available without hardware binding (non-ICOM lock or license-free)? Would be great to know what the latest stable version is that still runs. Thanks in advance! 🙏
