PSdZData FULL Requests (Programming Firmware)
8 reading
1.1M views 11K replies 3.9K participants last post by  adimalka
#1 · (Edited by Moderator)
Hello,
I have version 57.3
Is there a newer version?
What is the newer version?
What does it give over the older version?
Most important, is it needed for a 2016 M3?
#1,248 ·
#1,256 ·
PM sent.
Although I cant imagine why you would need Full version for Programming with a brand new 18 F22. There are no newer firmware files is latest PSdZData Full then what is already on your car's modules. :dunno:
#1,257 ·
#1,258 ·
I own a F10 and previously started looking into coding the vehicle myself. I work at a bmw shop that currently uses a fairly unreliable coder to remote into do any coding needed. I have been reading seans and dreams post the last couple days and seems to be fairly straight forward on using e-sys. I haven't been able to wrap my head around how to use or under what the psdzdata is. I have read all the links provided through these forums on how to get started with no luck for understanding exactly what im changing. Any way to explain or give reading material on what to do.
#1,259 ·
PSdZData are the ECU Data files for all the Control Units. Without it, you can't Code or Program any ECU.
#1,276 ·
#1,280 ·
Hi Shawn,
I got a untouched 2013 F30 and recently, I got a drivetrain error. I used ISTA+ to delete those fault codes but one of them can't be deleted (D0157A). Technician suggested me to have a ECU update co's mine is too old. I decided to give it a shot by myself but doubt if I can have ECU flashing with fault exist.
If it's ok to flash it, may I have the latest PSDZdata (full) and E-sys for my flashing? It's nice if there is any tutorial for ECU flashing. Thanks in advance.
daigorho
#1,281 ·
...If it's ok to flash it, may I have the latest PSDZdata (full) and E-sys for my flashing? It's nice if there is any tutorial for ECU flashing. Thanks in advance.
daigorho
PM sent.
#1,287 ·
