581 - 600 of 10,878 Posts
Hi Shawn could you please send me the links to 3.61.4 full many thanks
PM sent.
So you will flash car from 61.3 to 61.4? You update ECU firmware with every new release?
PM sent.
Thank you Shawn
I've been using my esys on mostly newer or brand new cars.
I'm still in the learning days yet but my next door neighbor lets me use his MY16 F31 for practice and also my friend has an new F80 M3 and I do updates for them each time there is new pszdata to keep my mind active with it all..
I really do appreciate the knowledge and advice you give here its by far the best :thumbup:
Thank you Shawn
:thumbup:
One quick question?
Have you come across a way of coding out to remove the flashing hazard warning lights when coming to a stand still after hard braking? My good friend wants me to try do this on his F80 M3 but i can only assume it would have to be removed with the flashing brake lights too?
:dunno:
FRM or FEM_BODY => WB_GB_ENABLE = nicht_aktiv to disable Hazard Lights on Emergency Braking.
Can you help please
Hi...could you please send me the link for the latest PSDZdata file for my 2012 F10
Thanks very much..I have downloaded everything else but want to make sure I can flash my software to the most recent and best data file
Thanks very much indeed
Alex
Alex
PM sent.
So, I obtained all the necessary files, but am not having any luck getting a response from fxxtokenmaster@gmail.com
I provided the Request code and version number a few times via email, but only get the following response:
Thanks for your email. I will respond as soon as I can. Expect delays in my reply.
Launcher Premium version 2.7.0 is the latest, ensure you are using the latest version always.
NOTE: This is an automated response. Do Not Reply to this email.
E-Sys Launcher Premium V2.7.1.135 Request Code: CS1341DC65D4544707
Thank you!!
Any ideas on how I can obtain the activation code?
Thanks !
Thank you!!
Thanks !
It can only come from TokenMaster, and he is out of pocket. If you do not run in a Virtual Machine, and you are using Normal U.S. / English settings, you should not need an Activation Code.
