PSdZData FULL Requests (Programming Firmware)
1 reading
1.1M views 11K replies 3.9K participants last post by  shawnsheridan
#1 · (Edited by Moderator)
Hello,
I have version 57.3
Is there a newer version?
What is the newer version?
What does it give over the older version?
Most important, is it needed for a 2016 M3?
#1,564 ·
Hi everybody,
I have the problem when I use PSdZData 3.63.3 on my F48 with current I-Step F056-17-11-540 to read ECU, it show two errors [C012] of BKOMBI file cafd_00000760-007_003_032 and DSC2 file cafd_0000297a-101_173_002 have not been found.
Is PSdZData 3.63.3 only supported to the I-Step F056-17-11-531? Any latest version?
Thank you.
#1,568 ·
#1,573 ·
Hi Shawn,
I´m currently using esys 3.27 with PSdZData63.3 lite and I´ve dots for the most ECUs. And it cannot find the following two CAF´s from DME_BAC2 "CAFD_000029B7_000_020_011" and DKOMBI3 "CAFD_00002660_007_003_10"
I´ve ILEVEL S15A_17_11_530.
Maybe you have a working PSdZData for my g30.
Thanks and regards,
tepoli
#1,574 ·
Hi Shawn,
Thanks and regards,
tepoli
PSdZ has no descriptions. As long as you are not getting "not found [C012]" error when "Read Coding Data," there is no reason to switch.
Try removing some kiswb, and adjusting memory settings. If using Pro launcher, make sure to add 64-bit java.
#1,576 ·
#1,584 ·
hi!
what is PSdZData last version?
after full sw update (with rear cam problem reason) can't disable seat belt warning sound.... no options what was in previous CAFD...
Previous system 03.17
Now - 11.17
I have here PSdZData 63.3.003....
But no SeatBeltReminder_Beihafrer present..... maybe new version of PSdZData can help? or another way to disable this belt sound?
#1,586 ·
hi!
Now - 11.17
You have the latest. You only need new PSdZ if you get "not found [C012]" errors when "Read Coding Data."
The issue is mapping has not been updated, but FDL's are there.
#1,588 ·
thanks for your reply!
The issue is mapping has not been updated -- what it mean? How to do it?
You break into BMW AG vault, get master Untrimmed CAFD and FAFP files, and then send them to TokenMaster so he can udpate his Mapping Database in Launcher PRO.
