PSdZData FULL Requests (Programming Firmware)
1 reading
1.1M views 11K replies 3.9K participants last post by  shawnsheridan
#1 · (Edited by Moderator)
Hello,
I have version 57.3
Is there a newer version?
What is the newer version?
What does it give over the older version?
Most important, is it needed for a 2016 M3?
#1,677 ·
Could I gwt the latest full download of Psdzdata also? Thanks
Not possible. Your PM function is disabled. When it is working, send me one.
#1,682 ·
Hi Shawn.
Dealer upgraded recoded some functions during disagnosis / repair, and now ESys (v 3.27) cannot read ("File for "cafd_.... not found! [C012]"). I think I need the latest PSdZData lite. Can you kindly send me a link please.
Cheers.
PM sent.
#1,690 ·
#1,694 ·
I have formatted my computer.
Still windows 8 64bit as before
Installed esys and laucher as always. net framework up to date
cannot run launcher - when i click two times nothing happens, computer reset, unistall and again install does not help
any solution?
Contact TokenMaster.
#1,696 ·
unistalled
installed 2.7.1 instead of 2.8.0 unfortunately this time it asks all the time to generate token. generates and aks again - anyone? or only token master
All older versions create expired .EST Token. 2.8 is only working version. If you can't get it working, try another PC or contact TokenMaster.
#1,697 ·
Hi, Shawn:
Thanks for sharing the data set.
I have a few questions. The i-level on my car is F025-14-11-505, which matches to ISTA-P Px.54.3. I only intend to code the replacement RDC module to it works and I don't intend to upgrade the i-level.
Will using the current version of Psdzdata trigger the update of i-level for the related ECUs? If so, was there an archived psdzdata set that matches ISTA-P Px.54.3 by any chance? I am not sure if the data set is segmented by model. The portion for F025 is sufficient for me.
Lastly, is there a standard procedure to do this? Is this to flash the module?
Thanks.
#1,698 ·
