7,421 - 7,440 of 10,895 Posts
PM sent ista+
Thanks for this Ista+ .. I believe my CIC needs recoding well that is what it says in ISTA D . I do have previous TAL, SOL and CAF module extracts . Can i do this using Esys and an enet cable?
At present i'm having issues with my NAV not showing map correctly and car on the road etc.. so nav is not usable. I have tried 2021 and 2022 maps still the issue persists...
Part of the error for CIC says this "An attempt was made to encode the control unit with a non-approved data record." and to reencode..
That was stored for months and when i updated the maps then i have this issue...
I hope i can code or flash the CIC using esys and need some help!!! Thanks
Yes, you can use E-Sys 3.30.1 or higher and latest psdzdata to flash CIC.
Thank you Shawn i will download and install the software stated above do i need to backup like fsc keys etc before doing so ?? A little stuck on this i do have backup TAL, SOL and CAF module backups... I also have one hex key and and FSC key...
No need to backup anything.
