PSdZData FULL Requests (Programming Firmware)
1 reading
1.1M views 11K replies 3.9K participants last post by  Moore Ben
#1 · (Edited by Moderator)
Hello,
I have version 57.3
Is there a newer version?
What is the newer version?
What does it give over the older version?
Most important, is it needed for a 2016 M3?
#2,180 ·
#2,187 ·
I am not even sure what "which level i need to code" means. :dunno:
As always though, use latest PSdZData (v.4.11.20_PSdZData) and you should be fine.
#2,197 ·
Thread is for Full PSdZData only, and nothing else, and if you have Full PSdZData you would never need Lite version. PM sent.
#2,201 ·
#2,207 ·
Hi,
I bought a screen 10.25 "(android 7.1) for my f20 of 2012 and I no longer have the programming I had done as the fog lights when I turn the steering wheel, light door in the back ..
I have to reprogram everything? or it will not work?
And can you send me esys and psdzdata please
Thank you
Thread is for PSdZData Full. Nothing more. If y9ou want E-Sys, look here:
Fxx-/Ixx-/Gxx-series Coding: (No Request) Latest Software Links
http://www.bimmerfest.com/forums/showthread.php?p=10193333#post10193333
#2,212 ·
Esys working fine :)
Thanks To shawnsheridan!
Any idea where is drl tail Light activation in f30 with Led tail Light?
3062 taghfahr mapping doesnt seems To work And i Cannot find mapping universal 6 et...
LCI or not, you should just have to add these to FA and then VO Code Head Unit and Light Modules (FEM_BODY & REM):
8TL Daytime Lights Front and Rear Active
8TN Daytime Lights About Light Menu Adjustable
Then go under iDrive Menu Option and enable DRL.
You do not need to FDL Code it.
