PSdZData FULL Requests (Programming Firmware)
2 reading
1.1M views 11K replies 3.9K participants last post by  adimalka
#1 · (Edited by Moderator)
Hello,
I have version 57.3
Is there a newer version?
What is the newer version?
What does it give over the older version?
Most important, is it needed for a 2016 M3?
#2,261 ·
#2,277 ·
Hello Shawn you already sent me a link to the current Pzd but I just want to ask if that is usually the current one the dealers also use?
Sent from my SM-G950W using Tapatalk
It is ripped from Dealer's ISTA system.
#2,280 · (Edited)
Hi,
I have a F30 with current level F020-13-11-502, last treated with ISTA/P 2.51.1-ISTA/P 2.51.2.
I know that's an oldie...Do you know where I could get the required files for this?
Thanks much!!
Files required to do what exactly?
#2,283 ·
Ah, ok. I was planning to code out the foglights but it looks like I would have to find a pretty old version of the psdzdata files. So it looks like I would have to flash the ECU to the latest version and then would be able to modify the foglights if I understand correct? The ECU has had a tune applied to it, so I guess I will need to contact the tuner first before going down that road or I'll likely wipe it out. Anyways, Thanks for the link!
Why old version? I just wrote >= (greater than or equal to) last version used to program the car, that would include the latest PSdZdata. All you need is here:
Fxx-/Ixx-/Gxx-series Coding: (No Request) Latest Software Links
https://www.bimmerfest.com/forums/showthread.php?p=10193333#post10193333
#2,286 ·
Hello Shawn!
I have some problems with my left Headlight Driver Module, which I have replaced and now needs to be programmed. No workshops in the area is able to program just 1 module, so I am now in need of the full psdzdata do I can do it myself. (They charge more for programming than the module costs)
Thanks in advance!
#2,294 ·
I thought you prefered by the thread sorry. Next time I will use PM. ;)
No, not at all. I personally find Thread post software requests a waste of space. They do not benefit the community, so no reason to make request public.
