PSdZData FULL Requests (Programming Firmware)
3 reading
1.1M views 11K replies 3.9K participants last post by  shawnsheridan
#1 · (Edited by Moderator)
Hello,
I have version 57.3
Is there a newer version?
What is the newer version?
What does it give over the older version?
Most important, is it needed for a 2016 M3?
#2,395 ·
I never changed anything in FA as I don't need it. My car is F23 and I bought it in 2015 (July).
You know when you have missed to select the car you have in ESYS Launcher, there is a process to add 2 days on your computer date and launch again ESYS launcher. What is the exact process to have the right token for the actual date?
I have an error in code FDL as I explained sooner
Thanks a lot
#2,396 ·
The right .EST Token is to generate .EST using real and correct system Date. You tried to outsmart the 3 day restriction, but now you are likely screwed now. TM built in Date Manipulation protection in newer Launcher. If Launcher refuses to Launch, only solution I have seen that works is a fresh install of Windows.
If it sill launchers though, and you are using correct Car Series and Connection Target, then your FDL Code setting is simply not valid / compatable, so it errors out.
#2,404 ·
#2,425 ·
Please send me link for last psdzdata full for flashing and last esys, insta-d and insta -p. Thanks a lot
Just as the thread Title indicates, this thread is for PSdZdata Full, and nothing more.
PM sent.
#2,429 ·
