PSdZData FULL Requests (Programming Firmware)
4 reading
1.1M views 11K replies 3.9K participants last post by  shawnsheridan
#1 · (Edited by Moderator)
Hello,
I have version 57.3
Is there a newer version?
What is the newer version?
What does it give over the older version?
Most important, is it needed for a 2016 M3?
#2,451 ·
#2,461 ·
Decided to finally install Esys 3.27.1 and thought I already had psdzdata...but can't locate it on my computer :tsk:
Not certain which version of Psdz would be most appropriate for coding both 2010 F07 & 2017 F31, but I appreciate guidance and link.
TIA
#2,463 ·
Hi everybody!
I had some ECUs (Car serie F56 - Target F45) updated by BMW hence some of my changes were lost.
Today I decided to re-code the changes
No problems in VO coding and FDL coding the HU_ENTRYNAV
But I had the following error trying to FDL code the BDC_BODY ECU
Transaktions-Report: Aktion: Codierdaten lesen
BDC_BODY [40] [xxxxxxxx]
readCPS o.k.
CAFD_000017BE_071_010_040 Fehler:
File for "cafd_000017be-071_010_040" not found! [C012]
I suppose because I got old psdz files.
Am I correct? In this case could anybody share the most appropriate files?
Thanks a lot
#2,468 ·
Do I need to re-code also the HU_ENTRYNAV even though it was coded with no error or it's not necessary?
Thanks in advance
Not necessary.
#2,473 ·
