PSdZData FULL Requests (Programming Firmware)
4 reading
1.1M views 11K replies 3.9K participants last post by  chuckBeamer
#1 · (Edited by Moderator)
Hello,
I have version 57.3
Is there a newer version?
What is the newer version?
What does it give over the older version?
Most important, is it needed for a 2016 M3?
#2,818 ·
Hi,
I dont understand why the is 2 versions in the latest sw ?
I can choose between november F20 and july F20.
My car is an F30 LCI produced in august 2015.
Which version should I choose ?
#2,819 ·
Hi,
#2,828 ·
#2,839 ·
Shawn,
Here's the error that I get when trying to flash/program my F Series ECUs. Hopefully the file attached...
FA Null is VIN issue. You must select "Vin from FA", then hit Read FA, and then Execute TAL.
Do this:
1) Read FA
2) Select Read VIN our of FA & "Read VIN"
3) Then do all of the ECU Selects - blflash...
4) Do the Check Software
5) Then select the "Read VIN out of FA" which grays out the "Enter VIN"
6) Then do the Start...
#2,846 ·
Hi Shawn,
Would you please send a link for the the full PSdZdata ?
Thanks for everything you do here on the forum. :thumbup:
Cheers
PM sent.
#2,866 ·
Shawn, may I get the link for the latest PSdZdata full to do firmware updates? (Thanks for the Gracenote database earlier on the other forums! That update worked out perfectly.)
PM's sent.
#2,869 ·
