PSdZData FULL Requests (Programming Firmware)
3 reading
1.1M views 11K replies 3.9K participants last post by  shawnsheridan
#1 · (Edited by Moderator)
Hello,
I have version 57.3
Is there a newer version?
What is the newer version?
What does it give over the older version?
Most important, is it needed for a 2016 M3?
#2,924 ·
Thread is for PSdZData Full, and nothing more.
And if you have PSdZData Full, you could make Lite from Full, but with Full, there would never be any need for Lite version to begin with.
PM sent.
#2,942 ·
Hi Shawn, would you mind sending a link to latest full? Thank you in advance!
P.S. I'm new to BMW, and was searching for the difference between psdzdata full that have version numbers in the 14.x range and others that number in the 63.x range? I understand that there are both full and lite versions of psdz. Thanks again!
#2,943 ·
PM sent.
BMW Changed F-Series Programming from ISTA/P to ISTA+, so PSdZData version numbers changed along with it.
#2,962 ·
Thank you for The explanation!
Think i First will try with older File.
Where can i get this File?
Attached Picture of i-stufen...
F020-14-03-502 is your I-Step Shipment, not current. Current I-Step is F020-18-11-520.
Try injecting CAFD again using v.4.15.20_PSdZData. PM sent.
