Shawn,
I have some problems with psdzdata 59.5 and e-Sys 3.27.1.
Some CAFD Files are not generated.
After Software Update through Dealer today, he told me version 59 ist loaded...
Can you have a look please? Thank you in advance
Logfile:
FEM_BODY CAFD_00000794_015_046_220
IHKA3 CAFD_000016EE_113_112_011
GHAS CAFD_000007C3_015_001_00
REM CAFD_000007A1_005_041_008
SM2 CAFD_000000B5_012_006_004
SM2 CAFD_000000B6_012_004_002
VDC1 CAFD_000006C6_003_002_012
Transaktions-Report: Aktion: Codierdaten lesen
ACSM [1] [K320583]
readCPS o.k.
CAFD_00000911_004_000_001.ncd generated
ACSM [1] [K320583]
readCPS o.k.
CAFD_00000912_004_000_000.ncd generated
ACSM [1] [K320583]
readCPS o.k.
CAFD_00000913_003_005_004.ncd generated
AMPT [37] [K320583]
readCPS o.k.
CAFD_00000FA2_002_001_001.ncd generated
ASD [3f] [K320583]
readCPS o.k.
CAFD_00000F9B_001_026_000.ncd generated
DME2 [12] [K320583]
readCPS o.k.
CAFD_00000B0A_000_060_001.ncd generated
DSC [29] [K320583]
readCPS o.k.
CAFD_00001A33_001_003_003.ncd generated
EKPM2 [17] [K320583]
readCPS o.k.
CAFD_00000098_000_008_114.ncd generated
EMA [4d] [K320583]
readCPS o.k.
CAFD_00000CE2_006_001_008.ncd generated
EMA [4e] [K320583]
readCPS o.k.
CAFD_00000DDD_006_001_008.ncd generated
EPS [30] [K320583]
readCPS o.k.
CAFD_00001A2F_000_002_010.ncd generated
CAFD_00000794_015_046_220 Fehler:
Lesen des CodierprĂĽfstempels von ECU "ECUId:FEM_BODY_0x40" fehlgeschlagen. [C070]
"openECUConnection" fĂĽr den Link FEM_BODY_40_ETHERNET ist mit dem Fehler MCDError Severity: 2051, Error Code: 49184, Description: Object with name not found, Vendor Code: 3, Vendor Description: provided name FEM_BODY_40_ETHERNET doesn't map to an item fehlgeschlagen. [1694]
FZD [56] [K320583]
readCPS o.k.
CAFD_00000A07_002_018_000.ncd generated
FZD [56] [K320583]
readCPS o.k.
CAFD_00000A08_003_012_000.ncd generated
CAFD_000007C3_015_001_00ss0 Fehler:
Lesen des CodierprĂĽfstempels von ECU "ECUId:GHAS_0x0F" fehlgeschlagen. [C070]
"openECUConnection" fĂĽr den Link GHAS_0F_ETHERNET ist mit dem Fehler MCDError Severity: 2051, Error Code: 49184, Description: Object with name not found, Vendor Code: 3, Vendor Description: provided name GHAS_0F_ETHERNET doesn't map to an item fehlgeschlagen. [1694]
HC2 [8] [K320583]
readCPS o.k.
CAFD_00000160_003_004_025.ncd generated
HU_NBT [63] [K320583]
readCPS o.k.
CAFD_00000DED_003_015_016.ncd generated
ICM [1c] [K320583]
readCPS o.k.
CAFD_0000067B_002_013_011.ncd generated
CAFD_000016EE_113_112_011 Fehler:
Lesen des CodierprĂĽfstempels von ECU "ECUId:IHKA3_0x78" fehlgeschlagen. [C070]
"openECUConnection" fĂĽr den Link IHKA3_78_ETHERNET ist mit dem Fehler MCDError Severity: 2051, Error Code: 49184, Description: Object with name not found, Vendor Code: 3, Vendor Description: provided name IHKA3_78_ETHERNET doesn't map to an item fehlgeschlagen. [1694]
KAFAS2 [5d] [K320583]
readCPS o.k.
CAFD_00001148_000_027_001.ncd generated
KOMBI [60] [K320583]
readCPS o.k.
CAFD_000009C8_006_003_110.ncd generated
LHM [43] [K320583]
readCPS o.k.
CAFD_000010BA_001_008_051.ncd generated
LHM [44] [K320583]
readCPS o.k.
CAFD_000016BF_001_008_051.ncd generated
CAFD_000007A1_005_041_008 Fehler:
Lesen des CodierprĂĽfstempels von ECU "ECUId:REM_0x72" fehlgeschlagen. [C070]
"openECUConnection" fĂĽr den Link REM_72_ETHERNET ist mit dem Fehler MCDError Severity: 2051, Error Code: 49184, Description: Object with name not found, Vendor Code: 3, Vendor Description: provided name REM_72_ETHERNET doesn't map to an item fehlgeschlagen. [1694]
CAFD_000000B5_012_006_004 Fehler:
Lesen des CodierprĂĽfstempels von ECU "ECUId:SM2_0x6D" fehlgeschlagen. [C070]
"openECUConnection" fĂĽr den Link SM2_6D_ETHERNET ist mit dem Fehler MCDError Severity: 2051, Error Code: 49184, Description: Object with name not found, Vendor Code: 3, Vendor Description: provided name SM2_6D_ETHERNET doesn't map to an item fehlgeschlagen. [1694]
CAFD_000000B6_012_004_002 Fehler:
Lesen des CodierprĂĽfstempels von ECU "ECUId:SM2_0x6E" fehlgeschlagen. [C070]
"openECUConnection" fĂĽr den Link SM2_6E_ETHERNET ist mit dem Fehler MCDError Severity: 2051, Error Code: 49184, Description: Object with name not found, Vendor Code: 3, Vendor Description: provided name SM2_6E_ETHERNET doesn't map to an item fehlgeschlagen. [1694]
TBX [35] [K320583]
readCPS o.k.
CAFD_000011C5_001_010_009.ncd generated
TCB [61] [K320583]
readCPS o.k.
CAFD_00000DDC_001_023_004.ncd generated
TMS [41] [K320583]
readCPS o.k.
CAFD_00001082_035_000_002.ncd generated
TMS [42] [K320583]
readCPS o.k.
CAFD_00001083_035_000_002.ncd generated
TRSVC [6] [K320583]
readCPS o.k.
CAFD_00000223_013_009_019.ncd generated
CAFD_000006C6_003_002_012 Fehler:
Lesen des CodierprĂĽfstempels von ECU "ECUId:VDC1_0x76" fehlgeschlagen. [C070]
"openECUConnection" fĂĽr den Link VDC1_76_ETHERNET ist mit dem Fehler MCDError Severity: 2051, Error Code: 49184, Description: Object with name not found, Vendor Code: 3, Vendor Description: provided name VDC1_76_ETHERNET doesn't map to an item fehlgeschlagen. [1694]
ZBE3 [67] [K320583]
readCPS o.k.
CAFD_000011B3_001_002_011.ncd generated
