PSdZData FULL Requests (Programming Firmware)
1.1M views 11K replies 3.9K participants last post by  Darius9791
#1 · (Edited by Moderator)
Hello,
I have version 57.3
Is there a newer version?
What is the newer version?
What does it give over the older version?
Most important, is it needed for a 2016 M3?
#3,364 ·
#3,378 ·
Hi Shawn,
I'm trying to retrofit a 6wa extended cluster in my F10. I believe I would need psdzdata full to flash the kombi, if that is correct? Do you have a link to the latest psdzdata full that will work with Esys 3.27.1? I would very much appreciate it. Thank you in advance.
im not seeing the full link in that thread, just lite
PM's sent.
#3,389 ·
again, thanks to shawn for the link. the problem was my winrar client's version is too old. all i had to do is update to the latest version of winrar. last question, i'm new at this coding and if there's an idiot's step by step guide since i don't want to brick my car. what i have so far is :
1. ethernet to obd connector
2. pc running windows 10, latest veresions of java both x86 and x64, e-sys 3.27.1, pszd 4.16.30,
for now i only want to do FDL coding for my 2016 F30. any suggests will be greatly appreciated.
#3,394 ·
Hi Shawn,
May I please get the link to the latest full psdzdata?
And also could you tell me what I need to additionally FDL code to get 6wb retrofit working on F30 wiht NBT (next).
Thank you
PM sent.
6WB should not require additional FDL Codng. VO Code DKOMBI and NBT for 6WB.
#3,392 ·
#3,409 ·
Hey Shawn,
Can I have download links for the latest Psdzdata full as well please.
Which version of e-sys and psdzdata work better together that would you recommend for my 2016 F12?
I have Launcher Pro 3.0.1 and links to e-sys 3.28.1 & 3.31.0 that token master sent me.
Thanks for the help.
PM sent.
#3,412 ·
