1,561 - 1,580 of 10,901 Posts
Hi everybody,
I have the problem when I use PSdZData 3.63.3 on my F48 with current I-Step F056-17-11-540 to read ECU, it show two errors [C012] of BKOMBI file cafd_00000760-007_003_032 and DSC2 file cafd_0000297a-101_173_002 have not been found.
Is PSdZData 3.63.3 only supported to the I-Step F056-17-11-531? Any latest version?
Thank you.
Hi Shawn,
I´m currently using esys 3.27 with PSdZData63.3 lite and I´ve dots for the most ECUs. And it cannot find the following two CAF´s from DME_BAC2 "CAFD_000029B7_000_020_011" and DKOMBI3 "CAFD_00002660_007_003_10"
I´ve ILEVEL S15A_17_11_530.
Maybe you have a working PSdZData for my g30.
Thanks and regards,
tepoli
Hi Shawn,
Thanks and regards,
tepoli
PSdZ has no descriptions. As long as you are not getting "not found [C012]" error when "Read Coding Data," there is no reason to switch.
Try removing some kiswb, and adjusting memory settings. If using Pro launcher, make sure to add 64-bit java.
