PSdZData FULL Requests (Programming Firmware)
1 reading
1.1M views 11K replies 3.9K participants last post by  shawnsheridan
#1 · (Edited by Moderator)
Hello,
I have version 57.3
Is there a newer version?
What is the newer version?
What does it give over the older version?
Most important, is it needed for a 2016 M3?
#343 ·
You must Update, and then use:
E-Sys Launcher Car Series = F087
E-Sys Connection Target = F020
PM sent.
#358 ·
All is right with the world again. The 60.2 worked like a charm. Shawn PM me your paypal for a couple beers. Its hard to put a price on the effort you give to us.
:thumbup:
#360 ·
Hello Shawn,
could you please kindly send me the latest PSdzdata for ESys. I have actually v59.4.
Thanks in advance.
Kind regards
AW1962
PM sent.
#364 ·
... part 11 and 13 cannot be downloaded. There is an ERROR shown.
Work fine for me, and no one else have any problem. Maybe MEGA is just having a temporary issue.
#366 ·
Hello Shawn,
I just started the downloads several times; suddenly no error and now is is going fine.
Thanks.
Regards
AW1962
:thumbup:
#371 ·
#379 ·
Can you give me some guide or tutorial in order to do this? If I unistall ESYS and launcher and install again should work? I need the token from token master again? Many thanks
Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Left-Click on desired ECU => Click on "Detect CAF for SWE" => Select the latest CAFD as shown => Select OK => Right-Click on ECU (the ECU itself not the underlying CAFD) => Select CODE.
#386 ·
Please may I have the link to the latest PSDzData. Thank you Shawn
