PSdZData FULL Requests (Programming Firmware)
1 reading
1.1M views 11K replies 3.9K participants last post by  shawnsheridan
#1 · (Edited by Moderator)
Hello,
I have version 57.3
Is there a newer version?
What is the newer version?
What does it give over the older version?
Most important, is it needed for a 2016 M3?
#3,813 ·
BMW g05 trimmed
Hi, with the help of the links provided by Shawnsheridan, I successfully installed Esys 3.27 with launcher and I managed toclear some error codes i Had due to the installation of a dash camera
i also savedmy original CAFs
But when it came to FDL coding I could not do it because I was not able to read the description of the different items, all of them sid they were trimmed
I tried HU_MGU and the BDC_BODY3 ECUs, without success
I wanted code video in motion and some of the Eco/Sport modes
What am I doing wrong
regards
#3,816 ·
regards
Wrong Thread. Thread is for PSdZData Full, and nothing more.
I replied to your same PM.
#3,824 ·
PSdZ latest files request. Shawn I PM'd you, I apologize if we were supposed to just request in here, but I asked a few more questions in the Pm. I appreciate your time.
PM sent.
#3,823 · (Edited)
Shawn,
I have 2011 F10 and had to replace RDC module. Now I need to flash the RDC module and while doing so using esys 3.27 I get the error that 'No CAFD-MAPPING for base variant RDC found' when I click on 'detect CAF' for RDC. Please find the image attached.
What exactly do I need to do ? This seems to be more than updating the PSDZ data file.
Anmol
#3,825 ·
RDC Module, like ZGW, has no CAFD. It is not a codeable ECU. It can only be flashed.
Why are you wanting to flash it?
#3,828 ·
#3,859 · (Edited)
Unless you are flashing, or car is on a charger, motor needs to be running.
For Force flash RDC, in svt_ist, set Main, Sub, and Patch versions to 000 for the BTLD, and SWFL entries (Do NOT Change HWEL.), e.g.:
id 00000792
mainVersion 000
subVersion 000
patchVersion 000
This thread is only for PSdZdata Full, and has veered far from that.
Shawn,
I changed the RDC BTLD,SWFL values as you mentioned in xml file (attached).
At step 15, I do see the RDC values (pic attached).
On checking software, it says all software available, but on clicking START I get an error as attached.
I did the process 3 times and followed each step as mention.
Any idea?
Also, I cleared the codes using Esys and I got the message RESETTING TPM, drove 4-5 miles but back to TPMS malfunction.
#3,860 ·
Shawn,
Any idea?
Pictured where?
#3,849 ·
#3,850 ·
Sdp vs psdz
Hey guys, I'm running out of disk space here. At one point I downloaded a complete package including SDP 4.13.11.
Now I've recently been given a link via PM for v.4.18.33_PSdZData_Full.rar. Is SDP the same as PSdZ ? Can I erase the old psdz folder created from extracting SDP files into the Rheingold folder and replace with the new PSdZ data ?
My purpose is to have an all around capable laptop. ISTA+, ISTA/P, and E-Sys (including for updating modules).
Do I need the psdz data in both "C:/data" for E-sys and inside of Rheingold folder as duplicates? Can I just link E-sys to look for the data files inside the rheingold folder? Should I do the file linking with that one program that more or less creates a virtual shortcut to whereever the psdz data is stored so both programs can access it?
Does ISTA/P also look for PSdZ data location in order to work properly?
Sorry I know that is a lot of questions, but I know that my level of confusion can be sorted out with a few sentences.
Thank you in advance!
#3,851 ·
You want to share the Full psdzdata from ISTA+ to Esys using a Symbolic Link as follows:
1) Delete PSdZData Subfolder from C:\Data Folder (i.e. c:\Data\psdzdata\)
2) Run CMD as administrator
3) Write - mklink /j "c:\Data\psdzdata\" "C:\Program Files (x86)\BMW\ISPI\TRIC\ISTA\PSdZ\data_swi\psdzdata\" <---(put your own directories)
ISTA/P doesn't use PSdZData. It is for E-Series Programming only, so it uses SP-Daten instead.
#3,866 ·
@Shawnsheridan,
Thanks for the prompt response. Am downloading the PsdZData now.
Again, pardon my ignorance, but, as I said, have been off the forum for a bit. What do you mean by "Update Launcher PRO 3.x to the latest via the Launcher App". I have Launcher Pro App check box for "check for Updates" checked, but it doesn't seem to do anything? Is there something else?
Appreciate your assistamce!
#3,876 ·
Hi.
Apologies in advance but a total newbie here. Have read through countless forums and pages of this and think i have my head around some of it. Ok so I got my F33 428i Convertible la couple of weeks back and wanted to try program some comfort features. I bought a cable and it came with the E-SYS software (3.27.1) i installed this and tried making some changes - i successfully managed to turn off the seat belt reminder, i did try to turn on Video from USB playback but that hasnt worked, but more importantly i wanted to be able tp fold mirrors with the key when locking and unlocking. I found the FEM_BODY and tried to read the CAFD file but it came up with the error "CAFD_00000794_017_068_102 not found"
Does anyone know a solution for this? or how i can program the mirrors?
I also wanted to ask if there was a way that i could operate putting the roof down or up just from the key? I used to hav a 330 which allowed me to do it from the key but in the 428 it doesnt seem like this is possible?
THanks in advance!
#3,877 ·
...,I found the FEM_BODY and tried to read the CAFD file but it came up with the error "CAFD_00000794_017_068_102 not found"...
Update your PSdZData. PM sent.
#3,885 ·
Hey also a coding noob here, getting ready to attempt to enable iDrive Touch features on my NBT HU in my 2013 F10 M5. Just grabbed E-SYS but need the latest PSDZDATA. It seems that shawnsheridan is the man to ask about this file.
So, Shawn, would it be possible to get a link to the latest files from you?
Thanks in advance!
