1,681 - 1,700 of 10,885 Posts
PSdZData
Hi Shawn.
Dealer upgraded recoded some functions during disagnosis / repair, and now ESys (v 3.27) cannot read ("File for "cafd_.... not found! [C012]"). I think I need the latest PSdZData lite. Can you kindly send me a link please.
Cheers.
Hi Shawn.
Cheers.
PM sent.
Can someone please message me the link for the full daten files for f series.
Daten or PSdZData? They are not the same thing.
I have formatted my computer.
Still windows 8 64bit as before
Installed esys and laucher as always. net framework up to date
cannot run launcher - when i click two times nothing happens, computer reset, unistall and again install does not help
any solution?
any solution?
Contact TokenMaster.
unistalled
installed 2.7.1 instead of 2.8.0 unfortunately this time it asks all the time to generate token. generates and aks again - anyone? or only token master
All older versions create expired .EST Token. 2.8 is only working version. If you can't get it working, try another PC or contact TokenMaster.
Hi, Shawn:
Thanks for sharing the data set.
I have a few questions. The i-level on my car is F025-14-11-505, which matches to ISTA-P Px.54.3. I only intend to code the replacement RDC module to it works and I don't intend to upgrade the i-level.
Will using the current version of Psdzdata trigger the update of i-level for the related ECUs? If so, was there an archived psdzdata set that matches ISTA-P Px.54.3 by any chance? I am not sure if the data set is segmented by model. The portion for F025 is sufficient for me.
Lastly, is there a standard procedure to do this? Is this to flash the module?
Thanks.
Hi, Shawn:
Thanks.
RDC is not a codeable ECU. It has no CAFD. Just install it. If you end up having to flash it, use latest PSdZData Full.
E-Sys - Flashing ECU Guide v.1.0.1.pdf:
https://mega.nz/#!VwIzGJJY!oHCQrh-axVrWvaB5E0pJKz73RO6b1syn-9eEytBH1qo
