Here's the thing - w/stock suspension, had BMW do fancy/ker-schmancy $295 Kinematic alignment w/weights. Result: OK ride & handling; excessive rear tire wear due to broken in suspension gone. Normal wear w/factory camber, yes, but gross, no.
Later: Yellows, Eibachs, M Parts; LSD. Full-on suspension replacement. Other'n LSD, I did the work.
Short of it:
The diff:
New vehicles should have alignment checked shortly after delivery & 5k mi later.
Looks like I don't need help to optimize my suspension; learn more about alignment every time I get into it.
If you want it done right....
Short of it:
- Did shade tree alignment....loved the result! But, toe was clearly not quite on the narrow.
- Took to local alignment shop.
- Got it back - ride degraded! Evidently inexperienced with ride height adj suspensions, they mucked it up. How one does that I've no idea - seems cut 'n' dried to me, and I'm not a pro.
- Did shade tree alignment again....loved the result! Chalked alignment expense up to foolery.
The diff:
- My ride now silky
- Turbo lag, she no got
- Brake bounce @ stop, she no got
- Mucho sa-mooth power delivery
- Sweet progressive grip, no end
- Step much smoother, including hyper mileing at speed
