Exactly, why?I can't imagine why anyone would actually want to do this (it's not safe thing to do), but it shouldn't hurt the car at all. You can switch into and out of neutral while moving all day long.
Probably not, but I don't see the reason unless you have few miles to go downhill. JMODoes anyone know if it's okay to put an F80/82 equipped with a DCT into neutral without causing harm to the transmission when coasting?
Tanti grazie Sebastiano
Popular Mechanics got it wrong.If you are coasting the engine is not using any fuel.
If the engine is idling in neutral it is using fuel.
http://www.popularmechanics.com/cars/hybrid-electric/a5977/coasting-in-neutral-fuel-economy/
Coasting outta gear can be a way to optimize mileage. Personally the diff in expense doesn't mean much, I just like to see how high I can push the mileage readout.....Popular Mechanics got it wrong.
It's true that modern cars use zero fuel when coasting in gear (engine being turned by the wheels). But that creates a braking effect on the car from the engine's compression and from the parasitic losses form the accessories (AC compressor, mechanical power steering and water pumps, alternator, oil pump, etc.) running at full speed. So, that car coasting in gear will coast less distance than a car coasting in neutral, and will therefore have to be under power for part of the distance that car in neutral would be coasting. Because it's under power part of the time the car in neutral is coasting, the car staying in gear uses more fuel.
Mercedes-Benz, in addition to Porsche, uses the "sailing" (coasting in neutral) function to save fuel.
I live on a barrier island. Gas in cheaper on the mainland. So, if I'm over there and near empty I fill up. There's a big bridge I go over to get back on the island. I reset the OBC MPG when I fill the tank. If I get a running go at the bridge, slowing down as I climb, it doesn't hurt MPG as much. Then I coast down the other side of the bridge for almost 3/4 of a mile. The MPG goes through the roof. Frau Putzer refuses to look at the readout when I point out my phenomenal MPG, though. She looks out the passenger window and says "Meow, meow, meow..." which roughly translates into "I'm not listening to you."Coasting outta gear can be a way to optimize mileage. Personally the diff in expense doesn't mean much, I just like to see how high I can push the mileage readout.....
It does wear out the throw-out bearing that disengages the clutch. I had a '76 VW Rabbit with 155k miles that had a noisy throw-out bearing.I've tried doing the 'right thing' and seeing what I can get but I just can't do it. My right foot gets in the way every time and I don't get through a tank in 'efficient' mode
I have a real dislike of the coasting in neutral or clutch to the floor. I cringe when my wife does it. At that point you aren't driving the vehicle. Not really in full control - IMO.
