Dear members,
Some time ago I have installed two oval cutout valves in the exhaust of my 550i 2011 (prior to the rear mufflers in the region of the rear axles) in order obviously to improve its original too quiet exhaust sound. I checked myself that the whole installation work was very well done (including all cutting and welding work in the stainless steel tubes) and the outcome in terms of sound is very good when the valves are opened. However, I have checked and confirmed on the streets (using chronograph and other supporting devices) that surprisingly the car's acceleration performance is quite worse when the valves are opened when compared to the situation when the valves are closed. Any reason for that? Does it have anything to do with backup pressure? It is really intriguing to me. I actually thought it would be the opposite outcome: performance would increase with the valves opened. Any idea why this is happening? Any similar experience with other members (incl. the ones who did muffler delete or even the so-called “replacing of perf pipe w/unperf pipe in the mufflers”?
