1 - 2 of 2 Posts
Can keeping the coolant at the full mark create a higher volume, causing more leakage, and failures because of the pressure in the cooling system? :dunno:
Pressure is regulated. If you look under the cap you will see valves, or they should be (I did not check on this BMW). If you overfill, system will kick out extra.
So no, having it on MAX will not create issues.
1 - 2 of 2 Posts
