I have a decent amount of play in my steering at highway speeds ~70MPH, and I want to figure out what the cause is. After reading up online, I found the basic check that everyone does. I lifted my car and performed the check by holding the front tire at the 3 and 9 positions and twisting and I could see that there was play. I found that on the passenger side tire, the control arm ball joint was loose (so I will have to replace that and it will hopefully fix the squeaking at low speeds), and on the drivers side tire, there was a bit of play, but nothing seemed to be loose. When shaking the tire I could see that all of the movement (about half an inch push in each direction) was being transferred into the center tie rod. I think that my flex disc may be damaged, and I might need to replace it. How can I inspect the flex disc without removing the whole exhaust system? When I get under the car I see the universal joint, but following it shows no flex disc. Another question, guibo, flex disc and steering coupler all refer to the same thing right? And am I taking the correct steps to solve my issue? Sorry for the essay.
BTW, I drive a 95 525i
