I THINK I kinda know what you're talking about and I'll try and be as descriptive as I can, but without pictures it's hard to figure out.obLu said:
First of all, there's a LOCKING NUT in the center of the adjustible swaybar link. Be sure once you have the link lenghth adjusted to a length of your liking, lower the locking nut to butt up against the bottom half of the adjustible link and secure it so the link does not move around.
Second, in the Bentley's manual it's actually recommended that the link does not sit exactly 90 degree to the upper arm, the diagram shows about a 97 degree relationship...or 83 depending on your perspective. Given that the mounting holes on the UUC swaybar is WAY shorter than the OEM sways, if you have it set on MAX STIFF it's not going to even be remotely close to the 97/83 degree relationship unless you adjust your swaybar links longer or shorter.
I hope one or the other (or even both adjustments) will address your issue. And from what I've know of Rob L. he's quite open to questions...That was how I opened a dialog and started receiving discounts on his items.
