1 - 8 of 8 Posts
Automotive Monomaniac
I see the coolant radiator, air/air intercooler and power steering cooler (?) through the front grille. What is to the right just in front of the wheel (driver's side)? Is that an oil cooler?
Why is there one little hole in the grate on the opposite side (passenger side)?
- Mike
Resident Curmudgeon
AC?
Traveling, so cannot look at mine....
Discussion Starter · #3 ·
AC?
I think the condenser radiator is sandwiched with the coolant radiator in the center... :dunno:
- Mike
Discussion Starter · #5 ·
Discussion Starter · #7 ·
I was hoping that it was for engine oil cooler since this is turbo charged engine :D
I'm thinking it is engine oil too... as that was an issue with the early N54 cars (which eventually got an oil cooler in the front fender).
I'd kill for an oil temp gauge - dump that stupid MPG meter! :mad:
- Mike
I have e39 that has diagnostic mode in dash display that you can view coolant temp, rpm, batt voltage and etc. and wondering if E70 has that same feature or not.
1 - 8 of 8 Posts
