I hope I am asking the right questions in the right place, if not, my apologies. If someone would be so kind as to direct me to where I should
Background: I have a 2014 320iX that runs fine, except for the HeadUnit which continuously reboots. I have come across several threads on how to fix it, but none seemed to work. After further research, the general consensus seems to be leaning towards updating the I LEVEL by programming with ISTA+.
Parts List: From the various threads I read here I gathered the following items
I connected everything and just looked around. I read one thread that said that before programming the errors needed to be fixed. Another thread mentioned just clearing or deleting the fault memory. So I opted to do that. QUESTION: Is deleting the fault memory an option to resolve the errors that need to be cleared BEFORE programming? And what if there are 2 that appear right away (foglight and parking light malfunction)?
After clearing the codes I took a look at the software update tab in ISTA+
I see that the I Level would be updated to F020-22-11-510. I then took a look at the Advanced tab:
Most units needed both Programming and Encoding. I was not sure if ISTA+ required me to follow the Measures Plan:
QUESTION: The measures plan is making it look like I have to install all of these units.
Thanks everyone.
- ISTA+ 4.39 with programming PZD or something like that also 4.39
- Schumacher INC100 Power Supply
- ICOMM Next
- Router/WAP
- Is this normal?
- Do I just ignore this section?
- Do I just click on Execute measures plan, and ISTA+ will take care of the rest?
Thanks everyone.
