So, after searching the forums, I haven't come across anything that really matches my issue.
Issue:
- Radiator fan not kicking in.
Side note:
- Will kick in if I manually give the fan a little turn. It will run for about 2 minutes then shut off again. Does that mean the fan is fine and maybe it's the signal coming from the computer? Idk.
What I've checked:
- Every fuse that I can find. All OK.
- Amperage coming from sed fuses. All OK.
- Voltage going to the fan through the 3 pin connector. 12.5V when the car is off & 14.7V when the car is on. Standard I suppose?
- The fan is holding a 12V charge after the fan connector is disconnected. Is that normal?
What I'm trying to hear:
- It's going to be a cheap&easy fix lol.
Thanks for any and all help!
Issue:
Side note:
What I've checked:
