1 - 4 of 4 Posts
Hello,
My radio regularly lose its DAB signal. Personally I think the signal is just fine because I can be in the same place on different days, and sometimes I have a signal and sometimes I don't.
Anyone with an opinion? I also think that when on FM radio it fails to re-tune to the strongest signal.
Stephen
Did you (or anyone else) ever find the cause or cure for this problem? It's just starting happening on mine. Odd because it's been fine for the 2 years I've owned it then, yesterday, it was searching for a signal much more than playing the DAB radio.
Z4 28i 2014
Thanks. Brian
DAB radio is as much use as a bucket with a hole in it! If you are stationary and get a signal then fine but as soon as you move you get the error message. I cant personally see any difference between FM and DAB but maybe that's just me?
If that's the case, my bucket has been completely holeless since purchase but has developed a leak now.
DAB radio reception has been excellent until my original post. Since then, it's been showing 4 bars on the signal strength meter but with "No Signal" against it and no sound at all.
Any ideas?
Brian
1 - 4 of 4 Posts
