Update you E-Sys and PSdZData.
E-Sys Launcher PRO 2.8.2_Build_162b BFU Edition was released May 2019, which was a repackage of E-Sys Launcher PRO 2.8.1 initially released in Aug 2017 with an .est Token that expired on "2022-06-13", so now unuseable. While there were newer E-Sys Launcher PRO 3.7.0 and E-SysX applications previously available, neither application is currently available from their respective Developer's any longer, besides which both now also have very outdated CAFD Mapping. As such, the best option for support of all F/I/G Series cars with current up-to-date mapping is the new BimmerUtility application.
E-Sys Package:
E-Sys - Installation Instructions - v.18.pdf:
mega.nz
E-Sys_Setup-3.40.2_64bit.exe:
mega.nz
PSdZData:
v.4.46.31_PSdZData_Lite.rar
mega.nz
- OR -
v.4.46.31_PSdZData_Full (MEGA):
mega.nz
v.4.46.30_PSdZData_Full (Torrent):
mega.nz
* NOTE: PSdZData Full Version is ONLY NEEDED FOR PROGRAMMING (FLASHING) ECU's and is NOT needed if only FDL or VO Coding.
BimmerUtility:
www.bimmerutility.com
* NOTE: For FDL Coding, E-Sys requires a 3rd Party “Mapping” application such as BimmerUtility as it Provides CAFD Mapping. Back in Nov 2014, BMW AG made changes to PSdZData beginning with 54.2 PSdZData where they removed (trimmed) all descriptive text from CAFD and FAFP files, making FDL Coding of ECU's difficult, as the FDL Codes can no longer be easily located. The "Mapping" application dynamically maps the trimmed data back into CAFD file making FDL Coding possible. BimmerUtility is NOT needed for VO (FA) Coding nor ECU Programming (Flashing) as these can be performed with E-Sys direct.
