1 - 2 of 2 Posts
Hi,
I am a new member to the forum, but a returning bmw owner. I now have a CPO 2008 550i sport with 48k miles and extended maintainance. Previous 3 models were 3 series; my favorite was the E30. Now to the point. I have had this car since january and have had my trans software reset. Now the whole right rear light assembly is dead: no brake lights nor reverse light. Any ideas. I plan to go to VOB bmw in rockville, but wanted to go informed.
Cheers
Check the connector on the wire harness going to the tail light. Make sure there is no corrosion or other type of damage on it and that it is plugged in properly. Make sure there are no water leaks that could have damaged it. I've read that CPO does not cover damage from water leaks. If the wiring or connector just plain shorted out though, then it should be covered.
BTW, make sure you just don't have a problem with burnt out bulbs.
1 - 2 of 2 Posts
