AirFrcd said:Yes.![]()
franka said:The ratio of the 2 gear ratios.
4.10 / 3.45 = 1.1884 = 18.84%
I'm just showing where he got it from. I'm not supporting it.
franka said:s62 said:The result is an increase in the "butt dyno" because of the strong but short torque bursts but you are not getting a big increase in acceleration.[/url]
s62 said:Ok, this is where the crazy number is coming from
Diff ratio changes do not increase horsepower.
Diff ratio changes do however change torque, you get higher torque multiplication BUT (and this is a bit BUT) for _shorter_ amounts of time because the shorter gears.
This has been discussed alot on m5board, see this thread for one: http://www.m5board.com/vbulletin/showthread.php?t=67150
AirFrcd said:I never stated that a change in diff ratio increases HP :dunno:
However, and I quote Jim Blanton from Performance Gearing "... and changing your diff from a 3.45 to a LSD 4.10 in a 530 will result in a net gain in accel. of approx. 18.5%."
I have not gone to the track / strip (yet) to test my times - however from a daily driver perspective (yes, I do drive my car hard), I can tell you that the increase in accel. is SIGNIFICANTLY noticeable and an absolute blast to drive (especially when combined w. the s/c) :thumbup:
franka said:That would take 1.5 seconds off your 0-60 time.
s62 said:I assume you are not talking about BMW 540/M5 and keep in mind that you cannot compare diff ratios between different cars because their gearbox ratios may be way different.
My point is this. I have not been able to get ANY hard data on performance improvement in 0-60 og 1/4 mile times with the change from the stock 3.15 diff to 3.45 or 3.64 in the M5. I have repeatedly asked people to show me that this mod does result in better times - nobody has been able to. And in the thread I pointed to earlier it is suggested that the cars with stock gearing 3.15 do better 1/4 mile times than the 3.45 ones.
fm_illuminatus said:I think the main problem with an increase in 0-60 times with a diff change is that the increase in acceleration is offset by the fact you have to shift into third before you hit 60 mph. That's why the butt dyno registers faster. The car runs through the gears faster, but that extra shift ruins the 0-60. However, I'd bet on an improved 1/4 mile. :dunno: Just my $0.02.
AirFrcd said:Depending on what your final drive is geared at now, let me tell you, upgrading my diff. from a 3.45 to a 4.10 LSD was by FAR the best mod that I ever performed to my 5'er :thumbup:
A net increase in accel of 18.5% is very noticeable, and a match made in heaven w. the forced induction (as the s/c kicks in only past 3K RPM's, and the shorter gears kick in as soon as you touch the skinny right pedal).
Cost was approx. $3,600 from Jim Blanton at Performance Gearing - btw, he is an awesome guy to deal with, and the authority in BMW gearing. I highly recommend his work and services![]()
franka said:IF ... If the original question that Demetrioss asked was about fitting an M5 diff in his automatic car the answer should be no problem because he is just swaping out diffs. He already has the auto box and the correct length drive shaft.
franka said:Where does expertise come in?
PropellerHead said:wrong. the auto tranny is longer than the 6 speed tranny in the M5 and you need a custom driveshaft to fit between the auto tranny and the M5 dif. He wouldn't know the length of the driveshaft until after the dif was installed and doing him absolutely no good. Akin to asking what kind of underwear one should buy for a SuperModel.
