1 - 1 of 1 Posts
Hey Everyone,
2011 N55 E70 100k miles.
For those of you familiar with the PCV valve of doom, https://www.e90post.com/forums/showthread.php?t=1384967, I'd like some advice.
I was getting some major howling from my rear main seal about a year ago, this is my car:
https://www.youtube.com/watch?v=rnR23pVVLGk
About 2 months ago the noise came back and wouldn't go away. I checked the PCV valve by connecting a hose and watching oil being drawn consistently through it. I did the hack job where I dremmeled off the PCV and replaced. The noise went a way for a couple months.
Tonight it came back. I tested the PCV again with the hose oil method and it isn't sucking oil into itself.
I am guessing my rear main is shot. I am decent at DIY's but I don't know if I want to pull the transmission on jack stands, I will most likely pay for it.
Do you guys think I should attempt the PCV valve replacement again, do a DIY valve cover, or just take it in to a professional indy shop? I have maintenance records that the valve cover was replaced around 40k miles by a dealership, it doesn't seem to be leaking any oil.
Thanks for any thoughts or opinions.
1 - 1 of 1 Posts
