1 - 5 of 5 Posts
BeeemerBro
5,4,6 BMW X3 All...196K +
Hello family...my x3 flows well these days just had to change out the transmission oil cooler....but my intermittent problem...while closing all windows with the fob, this one window is not in sinc and will sometimes not raise. So I walk away thinking I have secured the car only to find the passenger's rear window did not close....all ideas, leads and passed simular experiences are appricated and welcomed.
Sent from my SM-G386T using Bimmerfest mobile app
Nuclear engineer
02/2012 X5 35d M57Y CPO 105K miles NOKIAN WR G3 20K miles
Reset the pinch prevention.
Nuclear engineer
It is an electronic function controlled by the window switch only. You need to search out the instructions for your particular model. AND that may not be the solution to your problem, but it is an obvious possible cause.
BeeemerBro
Discussion Starter · #5 ·
An optional solution worth a degree of investigation
05 X3 175k
1 - 5 of 5 Posts
