ok, if the proper loom (wiring harness for us yanks) is being used, then i do not understand the question.
are you talking about the firing order for the ignition wires?? :dunno:
if so, then yes, the correct firing order is 1342. however, the coil towers for 1 & 4, 2 & 3, are sistered, so they will spark simultaneously, resulting in a 'wasted spark' on the non firing cylinder (which is on an exhaust stroke), if you have that sort of ignition system.
my google searches show me lots of stuff, so i am simply going to post it here for clarity.
i have 3 ignition systems, the one is a 'squarish' coil pack, the other a longer 'row' of coils in a pack. and finaly a coil over ignition.
i think this should help.
found an extra diagram of the m42 also, so i thought that would add it as well.
df
161.1 KB
16.8 KB
88.3 KB
21.2 KB
