1 - 5 of 5 Posts
Liverpudlian at heart
Hello. Years ago, before my warranty expired, I posted somewhere in this forum about my intention to pull the 80GB PATA hard drive from my car and take a precautionary backup image. Well, I am now well beyond warranty and my fear of drive failure incurring an expensive dealer repair exceeds my fear of borking my trim or iDrive unit.
Small form-factor (1.8", mSATA) SSDs and their adapters to legacy 2.5" mobile 44-pin PATA are ubiquitous and inexpensive - many times less than a new part from BMW anyway - so I am considering cloning my PATA drive to such a SSD and using an adapter to create a much more mechanically robust drive for use in my car.
I am confident that I can completely image the PATA drive including any funky non-standard filesystems and partitions to a SSD. I'd first try a block-by-block dumb copy using Linux's 'dd'. I also have some other tools to hand if that doesn't work. I would even experiment with expanding the partition used to store music to whatever size is supported by the filesystem I discover.
I cannot as easily copy or spoof the original PATA device IDs, serial numbers, and other intrinsic identifiers though.
Has anyone cloned/replaced their PATA drive without invoking professional assistance from BMW or their agents? If they have then I can presume that the iDrive does not expect a known, registered, hard drive and that my proposed SSD clone would be accepted. My ambition is that electro-mechanically the iDrive would not be able to discern the difference between the original OEM PATA drive and my clone.
I'll post updates and directions here.
Frank.
Has been done many times:
http://www.bimmerfest.com/forums/showthread.php?t=841458
BMW should have used an SSD to begin with in an environment they know would be exposed to excessive vibration and impact. I understand the need for cost savings but SSDs are getting cheaper and cheape. For the price you pay for a nav package upgrade, you'd think they would have invested a bit more for an SSD not only from a reliability stand point, but also from a performance one as well.
Yep, had an SSD in mine for many years, used clonezilla, car does not care about anything device ID, just clone it 100% and your good to go!
Did it speed things up?
Maybe a little, the issue is that it has to go through the PATA interface, so that is part of the bottleneck, on the SSD reads will be a bit faster as it is consistent no matter where the data is and has not rotational latency, so it is a bit faster, but not like 3 times faster. Boots a bit quicker and has no lag between menu items.
1 - 5 of 5 Posts
