1 - 7 of 7 Posts
Car has 50k miles. I want to replace known weak points on the car, as I have a rather long commute to work, and would gladly spend 1k if it means cutting down the chance of getting stranded and needing a tow.
My question is, should I replace the radiator and expansion tank, or rad/tank/thermostat/water pump/belts all at once? (inde. shop doing work)
Any advice is appreciated.
wrencher
I would if you could for peace of mind.
just havin a heart attack
the radiator removal leaves a LOT of space to remove the rest of it, and it will make your indie a lot happier than if he has to use the limited space when the radiator is in there.
Discussion Starter · #4 ·
Have another question. How exactly do I find out EVERY part I need to order for the job? Will reading through the service manual provide part numbers and such?
wrencher
I wrote this post for 528i, 540i is similar
http://bimmerboard.com/forums/posts/199986
I did my 528i at 89K, your 540i cooling system components seem to have a shorter life, so at 50K miles, it is not unreasonable to change them.
DIY and save lots of money.
HTH
cn
98 528i
I wanna DRIVE!
Here's what I did.
I replaced my radiator/waterpump/tstat all the hoses (and the belts while I was at it) for precisely the same reasons you cited. Check this.
1 - 7 of 7 Posts
