I couldn't find a DIY to replace my driver's side Xenon. Here's what I did:
- Jack car using standard floor jack & adapter
- Pull E brake & block wheels
- Remove wheel
- Place support under frame in case of jack failure
- Remove all screws on forward wheel cowling using 8mm & 10mm for single nut
- Remove 6 screws under front bumper
- Unplug fog light
- Set cowling aside
- Remove (T20) torx screws on lamp housing cover
- Remove wiring harness by gently working free
- Unclip D1S lamp by squeezing bottom of wire clip together (Note, the loops on the clip are not through the bracket; the bracket is open allowing the clips to be squeezed together)
- Remove lamp
- Replace with new lamp
- Replace clip putting top in first
- Plug harness back in
- Replace housing cover
122.3 KB
69.4 KB
72.2 KB
