1 - 4 of 4 Posts
That looks great, I actually need to do that too at some point lol. I had a motor swap done and now that exact piece is all messed up like yours was.
About how long did it take you ?
Discussion Starter #3
Thanks!, took about an hour and change....did it on my lunch hour today... pretty ez...
Remove the 2 air intake horns
Remove the intake and V/C covers
Remove the hood to firewall rubber seal
Pop up the 3 metal spring clips that are revealed when lifting the rubber seal off
Remove the 4 plastic fasteners
Get the new one into position
Work the wire harness rubber into the slot
Now work the panel into place and line up the holes
Get a plastic fastener into place on one side then the other
Slip the clips on at the top
Put the other 2 plastic fasteners in
Put the air intake horns back in
Rubber hood seal back in place
Valve and intake covers back on
Sit back and admire your work!
Dang you made it seem a lot easier than I’m sure it is of a hassle lol.
Sounds like a solid write up, add some pictures and you have a effect DIY.
Hey... if you need to redo one to get some pictures, I think I might know a car that could use it! lol thanks!
1 - 4 of 4 Posts
