1 - 2 of 2 Posts
Hello,
I replaced my solenoids, sleeves, and pan then refilled the transmission with fluid and car didn’t start. I tried jumping the battery that didn’t work there is no issue with the battery. I dropped the transmission pan again made sure the sleeve and plug were put in right it still did not start. Then i moved brown selector switch the car started but it says neutral when it’s really in park. What did i do wrong and how do i fix it. There is now a new code that says 5008 on the diagnostic
2006 530xi 6 MT
Have a look at the FAQ section at this site: thectsc.com
When you bolted the valve body back on, you needed to pay special attention that the parking rod cylinder is in the correct position. If you didn't do that, it is probably the issue.
1 - 2 of 2 Posts
