41 - 60 of 144 Posts
hi, i just replaced my dead cic with a similar unit from ebay. when i initially turned it on, navigation was ok but after a restart, navigation is now greyed out. can't figure out what needs to be done.
any help is appreciated.
Need to :
1) VO Code Donor CIC
2) WIpe Donor CIC FSC Codes
3) Load OEM VIN Matching FSC Codes.
Hi, I want to replace my F10 CIC screen. I was told that i need to change the HU with the same one that came out of the car the screen is from. Is it possible i can have my old HU or do i really need to change it?
They are not married. You can replace screen (CID) only.
Do I now need to change my HU or i can code it to work normaly?
Assuming you replaced Screen with an identical unit, then you just need to inject CAFD in CID and VO Code it.
How I can fix my problem? Is it the same way as you said before (inject CAFD in CID and VO Code it)?
As I understand it, you replaced CID (Screen). Process is inject CAFD and VO Code CID.
How can i do it? Are there any instructions for this?
Connect => Read FA (VO) => Activate FA (VO) => Read (ECU) => Left-Click on desired ECU => Click on "Detect CAF for SWE" => Select the CAFD from latest I-Level shown (bottom one) => Select OK => Right-Click on ECU (the ECU itself not the underlying CAFD) => Select CODE.
Nothing happened. This is the screen that came up when I selected "Detect CAF for SWE". I selected the one I had my mouse on. Then I scrolled up to where ECU was and selected CODE.
Why are you coding HU_CHAMP instead of CID?
