1 - 6 of 6 Posts
Russian Bimmer
Hey guys ,
I've been facing few troubles with my LCM II in my car
So i decided to change it entirely , i know that there's some coding must be done , my question is
Should i buy with the same part number or just any LCM II would work ?
Another question , must i only put LCM II or i can upgrade it to III normal ?
Sent from my Redmi Note 8 using Tapatalk
You could use either, the LCM II might be easier to program as it will have all the same options you have now.
Russian Bimmer
Discussion Starter · #3 ·
thanks , do i need to check the part number also , or just any LCM II will do the work ?
I’m guessing you should at least have same or newer HW and SW versions.
Wat are the symptoms that make you conclude the LKM is bad?
Russian Bimmer
Discussion Starter · #6 ·
It started with the right high beam won't turn off , fixed it , then the parking light ( front right , rear left ) and then both the high beams don't work at all now in the dashboard the blue sign appears , but nothing work , tested the wires that connect to the lamp , no voltage at all
1 - 6 of 6 Posts
