341 - 360 of 813 Posts
BeeemerBro
5,4,6 BMW X3 All...196K +
Discussion Starter · #343 ·
BeeemerBro
Discussion Starter · #345 ·
What soap are you using?
Sent from my SM-G930P using Tapatalk
some spray my wife had from the bathroom and I bought some multi surface cleaner (Walmart brand) "Good value"....a good scrub brush for about half hour...done all before work. Yesterday morning took a paint scraper to the center counsel...this result gives me incentive to go after the 05 soon.
Sent from my SM-J727T using Bimmerfest mobile app
BeeemerBro
Discussion Starter · #346 ·
Kinda changing the subject, but I snagged up a BMW engine this weekend. I'm not sure which engine it is, but it's an aluminum block inline six.
See... this on eBay http://www.ebay.com/itm/142997463348
Seats and counsel seem to clean up well...maybe I'll get creative with painting. View attachment 828823
Sent from my SM-G386T using Bimmerfest mobile app
06 X3 199k
05 X3 181k
04 X3 162k
BeeemerBro
Discussion Starter · #347 · (Edited)
Rescue Reds steering is extremely tight remember I've done the fluid change...but will this part ease up the tight steering?
http://www.ebay.com/itm/202408044577 Research shows that was one of the complaints about the the early X3s... stiff steering...
Happy day after turkey day!
TA
It is the universal joint/flex coupling that is between the steering shaft and the rack. If it is seized it could cause the steering to be tight. I may be interesting to jack both front wheels in the air and without starting the engine see how free the steering is. It should offer almost no resistance. If you want to do a bit more diagnosis, you could pop off the tie rod joints and make sure both wheels turn easily. it si possible you have a seized ball joint or upper strut mount.
BeeemerBro
Discussion Starter · #351 ·
Ahhh! ok thanks...that's good info to follow up on!
starting to button things up for the interior Vehicle Car Auto part
Land vehicle Vehicle Car Car seat Vehicle door
Land vehicle Vehicle Car Minivan Vehicle door
BeeemerBro
Discussion Starter · #352 ·
BeeemerBro
Discussion Starter · #360 ·
Man...she sure was a looker in her day...got to sort out a few things yet : breaks, o2 sensors, rear diff. maybe MAF sensor,steering and locks.
Just cleared a airbag light :
safety battery terminal? I was certain these early X's didn't require registering the battery.
06 X3 199k
05 X3 181k
04 X3 162k
