1 - 10 of 10 Posts
I have a 2004 X3 that I am ready to do my first oil change on and I do have a question: How do I reset the oil service reminder?
Can I do it from inside the car or do I need a "tool" to do it inside the engine compartment?
If someone could walk me through it, I would appreciate it. :)
I did do a search and could not find an answer that way, sorry if I overlooked it.
John
John
What is the purpose of reseting the oil service reminder if your still within the maintenance time frame ?
cheers
vern
Probably has gone past the mileage limit for free service. If memory serves a special tool is needed to reset the indicator.
I would assume that BMW would not make it easy to reset the service indicator yourself - after all, you could then "cheat" and get your free oil changes more often! (although I'm sure that the onboard computer tracks all of that and it wouldn't really be possible to pull one on over the dealer)
If and when and I'm sure some have reset the service indicator it starts at " 0 " again, so how can you cheat and get a free oil change when it takes longer to get to 15,000 miles from " O " miles? Please explain.
cheers
vern
You can do it yourself
Search around, I've read on how to do it before but have never done it myself. No tool was required, all you needed to do was put the key in a certain position and push a button or two for a certain period of time. Sorry can't get more specific as I don't remember the details.
On the X3 you do not need a special tool to reset the service reminder. Here is the procedure, courtesy of Petren (search is your friend):
Procedure:
Ignition key must be off
Press and hold the trip odometer reset button in the instrument cluster (left button), and turn the ignition key to the first position.
Keep the button pressed for approx. 5 seconds until one of the following words appear in the display: "Oil Service" or "Inspection", with "Reset".
The service due is shown with "reset" if the coded minimum consumption limit has been reached and resetting is possible. If "reset" is not shown, the minimum limit has not been reached and resetting is not possible.
Press and hold the reset button again until the word "Reset" begins to flash.
While the display is flashing, press the left button briefly to reset the service interval. After the display has shown the new interval the following will appear: "End SIA".
The system can only be reset again after 2.5 gal (10 liters) of fuel have been consumed.
Thank you for your response. The forum is the best "tool" and the consumer knowledge base is truely unlimited.
If you can, please respond to the following. As I went through the process you described, I tried something different. With the ignition key turned to the first position, I held the left button for about 5 secs. As a result, I accessed a series of codes I could cycle through by pressing the left button. x stands for a figure
_XXXX _ _ 1.0
_ _ XXXX _ _ 1.1
XXXXXX 2 _ 1.2
XXXXXX _ _ 1.3
_ _ XXXX _ _ 1.4
XX _ XXX 0 _ 1.5
CS 0 _ 0 _ _ 1.6 or C5? 0 _ 0 _ _ 1.6
XX _ _ XX _ _ 1.7
What are these codes? Which ones can a person reset when performong home maintenance? How to reset these codes?
You feedback will be appreciated.
Found the answer to my own question as posted on
http://blog.litux.org/2007/06/10/bmw-obc-hidden-menus
Instructions to access the hidden OBC functions:
1. Hold Trip Reset while turning ignition key to ON position.
2. OBC should show "Test".
3. Press Trip Reset repeatedly to select function 19.0 that unlocks all the features.
3. Wait for display to show "Off".
4. Press Trip Reset for 1/4 second and release it.
5. With no delay press Trip Reset several times to select one of the following functions:
1 Car Engine and cluster data
1.0 46nnn Chassis nr/VIN serial number (last 5 digits)
1.1 4nnn K-number
1.2 690236 Cluster Part #
1.3 045210 Coding (04)/diagnosis (52)/bus index (10)
1.4 1200 Week (12)/year of manufacture (2000)
1.5 09_160 Hardware (09) and software # (16.0) of cluster
1.6 Not used
1.7 04__44 CAN-version (04) KI-revision index (44)
2 (test) Cluster System Test - Activates the gauge drivers,
indicators and LEDs to confirm function
3 SI Data
3.0 1098 Used fuel in liters since last SI (Service Inspection)
3.1 0231 Periodic inspection days; elapsed days (since last SI)
4 Momentary Consumption
4.0 0145+ Instant fuel consumption - 0145=14.5 liters/100km
4.1 0018 Instant fuel consumption - 0018=1.8 l/Hour
5 Distance Gone Consumption
5.0 082 Average mileage; 082=8.2 liters/100km
5.1 0536 Calc. km to refuel (momentary distance to go)
6 Fuel Level sensor inputs in liters
6.0 109330+ Fuel level averaged; Left half sensor input=10.9 liters; Right sensor input=33.0 liters
6.1 0439+ Total tank level averaged; vlgs 6.0: 10.9+33.0=43.9 liters
6.2 0442+ Indicated value (44.2) and tank phase
7 Temperature and Speed
7.0 021+ Coolant/Engine temperature (2.1C)
7.1 130 Ambient/Outside temperature - chg met 5 pts. 125/130/135
7.2 + Engine speed / Current RPMs 1/min
7.3 + Vehicle speed / Current Speed in km/hour
8 Input value in HEX form
8.0 1d0+ System voltage ADC-Value Hex code
8.1 26C33C+ ADC Values HG left/HG right
8.2 0000 ADC Value brake degradation sensor (000=o.k.)
8.3 18C ADC Value outside temperature
9 Battery
9.0 140 Battery Voltage - 140 = UB 14.0v
9.1 242013+?
9.2 074_78+?
9.3 0011+?
10 Not used
11 Not used
12 Not used
13 GonG Gong Test
14 Not used
15 Status cluster I/O-ports (bit codes) 0=low; 1=high
1st-belt contact, seat belt fastened=0; 2) ignition lock contact, key inserted=0; 3) door contact, door open=0; 4) clock button pressed=0; 5) SI reset=0, for reset=0; 6) EGS transmission failure=0
Status Digital Outputs (bits) 0=inactive, 1=active
1) Gong output; 2) Brake warning lamp; 3) Low fuel warning lamp; 4) EGA lamp; 5) seat belt lamp; 6) manipulation dot
16 Not used
17 Not used
18 Not used
19 Lock Status; unlocks functions in range 3-18
19.0 L-On/L-Off Unlock: press button when "L-Off"
20 Not used
21 Software Reset; reset OBC settings
00 End of test
1 - 10 of 10 Posts
