Hello guys, the previous owner of the car switched from manual AC to automatic climate control. The heating level works, the car is giving cold/hot air depending on the selection (of course it will not keep the degrees, only sends cold, hot air). The problem that I am facing is that I can not say in which zone the air should be sent (windscreen, face, feet, etc). That was controlled before using the wheel and now using buttons and whatever zone I select it doesn't work. Does anyone have a solution for this?
