what happens when s a rocker arm snapps?
whet to check for and how to replace it?
Your car runs like **** and you tend to ingest alchoholic beverages while you contemplate whether or not you can get it off with out removing the head. It's pretty obvious when you remove the valve cover.PhotoGuy30523 said:what happens when s a rocker arm snapps?
ohhhhhhhh i see, thanks dude.SWISS said:Your car runs like **** and you tend to ingest alchoholic beverages while you contemplate whether or not you can get it off with out removing the head. It's pretty obvious when you remove the valve cover.
