1 - 2 of 2 Posts
Anyone know know how to remove the cover over the roof rail bolts. I can see a rubber cover over what is the center mount but can't tell if it simply pulls out or if it is bonded and pulling it off will cause a problem.
Reason I want to get at the bolt is that I want to try and use the monting bolt to provide an extra earth for an antenna.
Regards Phil...
Just pull the plastic cover off Phil. You can use a jewelers screwdriver to pry one side off and the rest will come off easily.
1 - 2 of 2 Posts
