1 - 9 of 9 Posts
Investigative Tinkerer
Oops!
Is that when the phone rang?
(spot on floor)
Even more labor intensive, I used Techline's thermal dispersant coating on the Healey's rotor hat and edges (plus rear drums).
Surface must be blasted and cleaned with solvent; mask off all areas that are to remain uncoated; use airbrush to apply a ridiculusly thin amount (like .0015"); cure in an oven at 300 degrees (part temp) for an hour.
And you call yourself an enthusiast!
Looks great! I just ordered some Eastwood brake drum black for the Z3's rotors. In the spring I will get the Euro floating rotors from the M3.
19,585 Miles
Jon, why did you paint the aluminum hats? They clean up nice with scotchbrite pads.
I used the Griots cast iron color. Had the rotors bead blasted. Still a pain in the ass to paint. Three coats using Q tips etc.
It doesn't last. The rust starts coming though. Becomes an annual thing.
You also have to paint the ID on the disc surface. 1/4 inch on the back and 1/8 inch in the front in my case. OD, 1/8 inch.
Looking into powder coating the rears and cad plating the fronts.
A masking nightmare, just like doing the wheels.
Premium Member
Discussion Starter #8 (Edited)
It was a tossup on the hats. I wanted them to look uniform front and rear.
I don't think Griot's carries their paint any more. The Eastwood stuff is really nice. Don't get it anywhere you don't want it to go. I cannot get it off. Fingernails included. Can says "contents partially unknown". Andy bought the matte silver which is a shade lighter than what I bought. Of course he has solide rotors in rear which makes his work a little easier.
I did do the IDs, just like you. I cleaned any overpainting with scotchbrite.
I will not be pleased if this paint does not hold up. This project was a crapload of work. I did not bead blast. I used wire wheel on my Milwaukee
and also a wire pipe cleaner. I watched Office Space 6 times while I prepped them.
If powdercoat holds up better and/or cad plate, I am interested.
1 - 9 of 9 Posts
