I have a 99 e46 328i with problems that i cant identify. When i'm at idle in neutral and rev it up to about 5,000 rpm the needle on the rpm gauge do not go up smoothly. Also when im accelerating from a stop its not a smooth acceleration
. When i took off my oil cap i hear a weird noise when its running. I put my hand over it and it stops. The oil hole has a large suction when i stuck my hand over it. Could this mean that my Crankcase vent valve is bad? Would this be the reason for poor acceleration? Also i just replaced my MAF and i cleared my MIL and it came on when i accelerated hard again with P 0101. Every time i start it with the new MAF the idle jumps up and down then after a few seconds its normal. I believe it could be a leaking hose but i couldnt find one. Could this mean that my Air Idle Control Valve is bad? Could this be the reason for rough acceleration? I will be replacing my seals for the Vanos so i will see if that may be the problem.
HELP IS GREATLY APPRECIATED I MISS MY BABY RUNNING WELL
