1 - 5 of 5 Posts
I have a 2011 328i coupe, and I've been driving it for about 2 weeks and it's been blowing clouds white smoke when I push the gas more. And it didn't do it all the time, but I noticed it became more frequent. And I just got done driving it and about 20min later I went to go drive again and it started but it was now running very rough and blowing black smoke. I don't know what it could be. Any ideas how to find and fix this problem?
White smoke is an indication that water or watery liquid is being burned by the engine. Black smoke is an indication of an overly rich fuel/air mixture. That is the mixture has too much gasoline. Did you just buy this car?
Where are you located? How many miles/kms on the car?
Discussion Starter #3
No, I have had it for almost a year now coming up in March. I'm in Houston. I bought the car with 84,000 miles now it has 96,500 miles.
disregard injectors, I thought you said n54. If you are blowing white smoke. It could be failed PCV which is the valve cover assembly or you have a head gasket leak. It's very uncommon for a head gasket leak unless you overheated the engine.
1 - 5 of 5 Posts
